vrf Instruments in callable Vee
Question asked by VRFuser on May 13, 2008
Callable Vee has a program named veesm that acts as a sort of surrogate server that dispatches the rpc calls to Vee handler processes.  If you start veesm using the –veeio option, you can select whatever vee.io file you have access to.
Sent: Tuesday, May 13, 2008 8:20 AM
Subject: FW: [vrf] Instruments in callable Vee
Interesting – your thinking matches my own.  So I created a vee.io file, and put it in:
C:Documents and SettingswatlingLocal SettingsApplication DataAgilentAgilent VEE Provee.io
And
C:Documents and SettingswatlingLocal SettingsApplication DataAgilentAgilent VEE RunTimevee.io
(just to be sure)
Got the same error message!
I wonder if there is a third location for …callableVeevee.io ?
Dave
  _____
From: Street, Andy M [mailto:andy.street@tycoelectronics.com]
Sent: 13 May 2008 15:05
To: David Watling
Subject: RE: [vrf] Instruments in callable Vee
Hi Dave,
I am pretty sure that the information about the instrument is going to be in the external vee.io file that is associated with your logon.  Normally when a UF is imported into another VEE program, the IO calls inherit the IO config in the main program, but in the case of Callable VEE, the IO information is going to reside in the vee.io file.  There should be something about this in the Callable VEE Help File.  At least this is how life was in VEE 7.5 days - I have never checked it out in VEE 8+
Try tweaking on your vee.io file and see what happens...
Hope this helps
Andy
  _____
Sent: Tuesday, May 13, 2008 9:56 AM
To: VRF
Subject: [vrf] Instruments in callable Vee
I am trying to use callable Vee for the first time.
I have tried importing userfunctions into callable vee (from Excel VBA), and all is fine unless a userfunction contains an instrument call.  I just had one ‘Direct IO’ instrument call in my library, but this caused the import to fail with the message ‘Invalid device encountered, Prerun failed on User Function, etc…’.
Is this because the vee.io needs to be in a certain place?  Is there something I need to know about instruments within callable Vee?
Regards
David Watling
  _____
This e-mail (including any attachments) is intended only for the recipient(s) named above. It may contain confidential or privileged information and should not be read, copied or otherwise used by any other person. If you are not a named recipient, please contact the sender by telephone (+44-1454-284800) and destroy the original message. Any statement and/or opinion not related to this company's business and expressed in this message is that of the author and does not necessarily reflect those of Icera. This company does not take any responsibility for the views of the author in any matter not related to the company's objective.
  _____
You are currently subscribed to vrf as: andy.street@tycoelectronics.com
  _____
  _____
You are currently subscribed to vrf as: john_dumais2@agilent.com
