Hi Stephen,
It used to be if you had LabVeiw and Vee on the same Machine it was important on the order of install of the products. The issue was that LabVeiw would overwrite some of the Vee IO libraries but Vee did not do this. To keep things working right then you have to Install LabVeiw First and then Vee. If you have not done this then LabVeiw could have messed up the Vee Lib's install. If you only have Vee on the Machine in question then there is a possibility the NI card may need updated drivers.
Greg
"Estrin, Stephen" <ESTRINS@tycoelectronics.com> wrote:
Anyone ever get a the NI845X I2C interface to play with VEE? The card will play just fine with Labview (go figure but does not work with VEE we get errors like invalid device ID. Any suggestions?
Thanks in advance for any help!
Stephen L. Estrin
Test Engineer, Subsystems
Aerospace & Defense Solutions
TycoElectronics San Jose Operations
5300 Hellyer Avenue
San Jose, CA 95138-1003
Tele: 408.624.3173
Fax: 408.624.3917
email: estrins@tycoelectronics.com
You are currently subscribed to vrf as: sherekhan_kl@yahoo.com
_____
Never miss a thing. HYPERLINK "http://us.rd.yahoo.com/evt=51438/*http://www.yahoo.com/r/hs"Make Yahoo your homepage. --- You are currently subscribed to vrf as: ming_meng@agilent.com To subscribe please send an email to: "vrf-request@lists.it.agilent.com" with the word subscribe in the message body. To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com". To send messages to this mailing list, email "vrf@agilent.com". If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com". Search the "unofficial vrf archive" at "http://www.vrfarchive.com/vrf_archive". Search the Agilent vrf archive at "http://vee.engineering.agilent.com".
Greg
Stephen L. Estrin
5300 Hellyer Avenue
Tele: 408.624.3173
Fax: 408.624.3917
_____
Stephen L. Estrin
5300 Hellyer Avenue
Tele: 408.624.3173
Fax: 408.624.3917
