> Is there a way to get the socket handle number from the 'To/From
> Socket' object??
Kind of, but it's very back door & undocumented. It would probably be easier to use a socket library that supplies a handle property if you're looking for a portable solution.
MS supplies a few different socket libraries with most development products and there are literally hundreds of third-party libraries.
-SHAWN-
> Socket' object??
-SHAWN-
Is there a way to get the socket handle number from the 'To/From Socket' object?? I have a DLL where the calling program opens the TCP/IP socket and passes it to the function within the DLL. I have this working using Visual Basic which opens the TCP/IP socket and then passes it to functions called in a DLL. So I'm looking for a way to call the same DLL functions within VEE but need to pass the socket handle.
Pete Thomas
Senior Test Engineer
GE HealthCare
