Hi
I tried running the vee 8 example (from an out of date evaluation installation) using vee 7.0 and it ran fast every time (I am using Word XP if that is relevant).
I changed the "Disable Debug Features" in "Default Preference" as suggested in the notepad and it still ran fast but the exit from Word became slow!
I tried the word97datasheet vee 7 example using vee 7.0 and it sometimes ran slowly. It also displayed an error :- "Not found {Model}".
Is the problem only with Vee 8 and a particular Word version?
Les
----- Original Message -----
From: HYPERLINK "mailto:William.Drago@L-3com.com"William.Drago@L-3com.com
To: HYPERLINK "mailto:vrf@agilent.com"VRF
Sent: Monday, October 22, 2007 7:25 PM
Subject: [vrf] Word slow via ActiveX
All,
I'm currently writing code to transfer a LOT of data to Microsoft Word and the transfers sometimes take a very long time. And other times, they're lightning fast.
Even when I run the example WordDataSheet.vee found here:
C:Program FilesAgilentVEE Pro 8.0examplesActiveXAutomation
Sometimes it runs very fast, other times very slow. I haven't found a way to get it to run fast all the time.
Anyone have any experience with this sort of thing?
Bill
You are currently subscribed to vrf as: lesord@ntlworld.com
Les
All,
Bill
Bill
