Which version of VEE do you use?
If you use full MATLAB in VEE, you can use .m files in VEE MATLAB script, you don’t need to compile them.
If you use the built-in MATLAB engine in VEE:
In VEE 8.5, I don’t think it is possible. The built-in MATLAB engine of VEE is MATLAB Component Runtime. Please check these references from Mathworks:
http://www.mathworks.com/support/solutions/data/1-17FWRY.html?solution=1-17FWRY, http://www.mathworks.com/support/soluti ... on=1-QXFMQ , http://www.mathworks.com/access/helpdesk/help/toolbox/compiler/index.html?/access/helpdesk/help/toolbox/compiler/f10-998688.html#f10-998993.
2. In the versions before VEE 8.5, you can use .m files in VEE MATLAB script since the built-in MATLAB engine is MATLAB Runtime Server. But MATLAB Runtime Server was no longer sold as a separated product, for details: http://www.mathworks.com/products/new_p ... l?BB=1#MRS.
Cao Luo
_____
From: Losik, Vlad [mailto:losikv@tycoelectronics.com]
Sent: Tuesday, March 04, 2008 5:15 AM
Subject: [vrf] Matlab custom function
Hello VRF!
If I have full Matlab and Matlab compiler is it possible to create custom function which is callable from Vee Matlab Script ?
How would one do it?
Thanks
Vlad Losik
You are currently subscribed to vrf as: cao_luo@agilent.com
Cao Luo
_____
Hello VRF!
Thanks
Vlad Losik
Thanks
Vlad Losik
