Hello
I'm trying to log two channels from a DSOX3014A to a file on a USB device using the Command Expert.
My problem is that the oscilloscope hangs on some commands, the buttons does not respond to new commands or buttons/switches and needs a power cycle to work. Agilent Connection Expert also looses the connection. In some (1 of ~8) hangs, a power cycle of the oscilloscope doesn't help and the PC must also be restarted.
From my debugging so far it seems like commands like
:TRIGger:SWEep NORMal
or
:TIMebase:RANGe 5
makes the command
:WAVeform:DATA?
fail with the message
VI_ERROR_TMO: A timeout occurred | SCPI connection attempt timed out
I updated the firmware a few days ago, but I'm new to this way of controlling the oscilloscope, so I may have some "obvious" fault in Command Expert...
Have attached a screenshot of Command Expert.
Eivind
or
:TIMebase:RANGe 5
makes the command
:WAVeform:DATA?
Eivind
Second, if you just want to save the data to the USB, then you don't need the ":WAV:DAT?" commands at all. Those tell the scope to offload the data to the controller (PC).
Al
