Hi, I am using MSO9104A. I want to decode a non-standard SPI protocol (like SPI, but not). There are MISO, MOSI and CLK (no Chip Select).
I tried 14-days SPI option trail. My settings are as follow:
4 wire SPI;
MISO - Channel 2
MOSI - Channel 3
CLK - Channel 1
Chip Select - Channel 4 (I tried ground it and set "active low"; also I tried give it 5V and set "active high")
Auto Setup;
Trigger: Serial: Channel 3 (I want to select CLK channel as Trigger, but the only options are channel MISO and MOSI.)
Trigger (another try): Edge: Channel 1 - CLK; falling;
others are default.
I always got the message - "can't decode. not enough edge."
I just need to figure out how to decode MOSI and MOSI based on the CLK.
For example, I can decode some by hand. When CLK is active, count the level of MISO such as "high low high low low low low low" (101010000)bin=(A0)hex. Then, convert 8 bit binary value to hex.
How to use agilent oscilloscope to do this?
Thanks a lot.
4 wire SPI;
MISO - Channel 2
MOSI - Channel 3
CLK - Channel 1
Auto Setup;
others are default.
Thanks a lot.
Once you have chosen the channels correctly, if you have data running, then click 'Auto Setup'. The scope should figure out everything else out on its own, including timing, thresholds, etc. Have you tried that?
If it says you don't have enough edges, then either the depth isn't high enough, or the thresholds aren't set right.
Al
