One advantage of the new web enabled scopes is the ease of doing documentation. Logging in via the web interface using "Get image" is a real time saver.
Does anyone now if it is possible to add extra information to the picture header. E.g. the company information etc. (I attach a screen shot of how the current screen capture looks).
One solution, without adding new fields would be to add the "Network description" (that you configure in the Network setup) in the top line of the capture next to the Scope model and date/time.
I played around with Annotations (which is great for annotating the capture), but not to add company information over your measurements.
Is this possible? If not, is there a "feature request" section somewhere for future firmware updates?
It would help if you used a graphics editor and created a version of your picture, showing what you would like.
Al
