Hello All,
I want to know that how can I generate a known bit sequence via Agilent MXG Signal Generator N5182A for wireless transmission. I am new in this field but after some initial study I found that using the I/Q mode of N5182A one should send a known sequence but for that you have to generate an external file and upload it to N5182A having the values of I and Q. Kindly someone with knowledge of this or having some alternate idea; help me in this regard.
Best Wishes
Best Wishes
You can generate a known bit sequence using the Data In and Data Clock (and Symbol Sync) on the front panel. How to do this is in the User’s Guide chapter 7.
It can also be done by using a waveform file downloaded into the MXG. How to do this is explained in Chapter 8 of the MXG User’s Guide.
Using waveform files and downloading into the MXG is also explained in detail in N5162A, N5182A, E4438C, E8267D Creating and Downloading Waveform Files
This is available to download on our website.
Regards -
