Dear All
I Know (please correct me of I am wrong) that ADS does not do 3D plots. The work I am doing now requires me to do a lot of sweeping two parameters and observing the effect of that on the behaviour of a third in the circuit. As you would expect, a 3D plot is the best way to observe the results of such a sweep.
Do you know if there is any way (better than using a 2D plot) to observe the results of such a sweep simulation in ADS? Any thing near to a 3D plot.?
Apart from that, what is the easiest and fastest way to carry out the data from the data display window in ADS to any other software package where 3D plots can be made?
The way I do it now is in Matlab, but taking the data there from ADS and sorting it out in the correct format to be plot in 3D is a very lengthy and time consuming process especially when too many 3D plots need to be done.
Any suggestions are much appreciated.
Many Thanks in advance.
Ali
Ali
you can at least generate a contour-plot. Use the search word: "contour" and you get the link how to proceed.
Hopefully heplful!
Regards
Christian
