the Thread: Dataset storage location change
by creating symbolic link of the default data directory abc_prj/data to different location seems to be working but after applying some simulations something is wrong.
when applying this symbolic link trick to an existing project & moving the previous .ds files to different location it open ok & I can view the data. but when I try to simulate/generate new .ds files the new files looks very smaller in size & don't display any results (looked corrupted)
Is this issue still open?, I can find old threads were talking about same required feature
Write .ds file to an arbitrary directory
How to send .ds file somewhere else
Thanks
-Amr
The symbolic link approach should work in redirecting the ds file. It would be best for you to contact your local EEsof technical support team to address the issue you are having.
The contact information for Agilent EEsof technical support can be found here:
http://www.agilent.com/find/eesof-support
Edwin Yeung
