I have a laptop with a docking station and external monitor attached. When running the VSA software, the external monitor brightness changes (flickers) while running the software. Are there any settings on the pc that need to be adjusted or is there some setting in the VSA software that can help with this flicker? This doesn't happen with any other software that I use on my computer.
In case that is not the issue, can you tell me what version of VSA you are running, what OS you are using, what measurement you are running, what type of data you are showing, and how you were showing it?
