I'm using MXA for measurement.
I saw the current (A) option (attached) on the Y axis unit.
Can the measurement from dBM to directly convert into current (A) without using a shunt resistance?
Or must I use a current probe for measurement for better accuracy?
My application is to do current measurement using near field probe on my PCB and wires.
Hope you can help.
Hope you can help.
I do not have a good response for you via the Agilent Discussion Forum. I suggest you contact your local Agilent Technical Contact Center for assistance.
In the Americas: Contact us for general technical support. Toll-free:1 800 829-4444 Press #, then 2 fax:1 800 829-4433 hours: 8:00 am - 8:00 pm ET, Mon - Fri
Thank you -
