Hello
first i'm sorry for my bad english , second i've just started with Agilent 89600VSA , my task during my internship is to automate this instrument , Develop routines for auto-configuration and how to extract information(specially im in need of power values and EVM in 802.11n ), i read the doc , i find that i can automate with different languages (MATLAB, VB ...) using COM API , the problem is what i want to do is possible or not with VB and if is possible how can do it , i want just a recommandation or a useful website to start automation
I would be grateful
I would be grateful
Launch the software, go to "Help", and "Contents." This is the main help file and should be consider as "the manual." Go to the entry called "COM API Programming" and you will see a link that will launch a separate help file for all topics regarding programming using the COM API. In the new help file, you will see a topic called "Example Programs" and there are several written in VB.
You can also launch the help file without launching the software. In the Windows Start Menu, go to Programs, Agilent 89600 VSA, then Help. This is the default start menu entry.
