I am looking for the example files for the “Post-Layout Simulations with Momentum G2” part of the 2010 SI seminar:-
http://edocs.soco.agilent.com/display/eesofkcads/SI+Workshop+2010
While I can download the zip it does not contain the example file “Mom_wkshop_Feb2010_prj“ for Lab-1 in the file “SIWorkshop_1_2010_Chapter_momentum.pdf”any idea’s ?
Regards
John
Regards
John
The Momentum project that you are looking for has been added to the list of files for downloads on the page:
"SIWorkshop_1_2010_Momentum_Example.zip"
It is about 90MBytes and needs to be unzipped before opening in ADS. If you are using a newer version of ADS you will need to use the ADS File>>Convert Project... menu pick to open the project.
Heidi
