I have large circuit to simulate in ADS-DL. ( 2009U1)
in ADS unnamed nets begin with "_net" . The all nets which have this beginning name are not saved in the dataset.
By default Cadence netlister creates nets beginning with "net". There is no underscore. Then the dataset contains all nets.
This generates huge dataset which create freeze or crash ( dataset size > 40Gbytes)
Is it possible to avoid saving nets called "netxxx".
I still want to save named nets I have in the hierarchy.
any hint to workaround this problem ??
thank you
Edited by: R13801 on Oct 27, 2012 8:10 AM
thank you
Have you tried going to the Output tab of the simulation controller in the ADS schematic, and reducing the level of hierarchical depth for "Node Voltages" to 1, and perhaps use only Measurement equations to output the voltages of the desired named node or wire labels ?
