Option 049, Color Display became a standard option on the ESA-L series of analyzers in September, 2003. If you reply with your instrument serial number as well as the battery date, both of which are located on the rear panel label on the instrument, that would help determine the vintage of your instrument and if the 049 license should be installed free of charge. If your analyzer precedes the September, 2003 date, you can order the 049 upgrade as E4411BU-049 from Agilent Technologies. This order will provide an entitlement certificate that will allow you to obtain an 049 license specific to your analyzer serial number.
Regards -
