I'm using 33522A to generate a sine wave at 325Hz, -5dBM to input onto a MXA.
See attached.
I autotune to detect my spot frequency, but the MXA is unable to detect any.
I set the frequency at 10Mhz and autotune, MXA can detect this signal.
Later i set up my start frequency at 300Hz, stop frequency 1MHz.
MXA is also not able to detect my signal at 325Hz. See attached pic with marker at 325.2Hz.
My application is to measure the fundamental frequency at 325Hz and up to 5th harmonics.
But now, MXA is unable to detect such low signal.
Can it be due to my equipment issue? or is there a limitation at low frequency measurement?
Hope you can help.
See attached.
Hope you can help.
I do not have a good response for you via the Agilent Discussion Forum. I suggest you contact your local Agilent Technical Contact Center for assistance.
In the Americas: Contact us for general technical support. Toll-free:1 800 829-4444 Press #, then 2 fax:1 800 829-4433 hours: 8:00 am - 8:00 pm ET, Mon - Fri
Thank you -
