What if I had a 12 port in genesys, and wanted to see S11,11 on a smith chart output. What do I put in to the graph dialog box.
S11, S33, S99 all work well for port 1, 3, and 9 respectively. But when I tell it to graph S11,11 it flips out. I gues it does not like the comma. Unfortunately, it also does not like S1111.
BTW, this forum is dead. Anyone out there still using genesys???
Also in the Graph Properties -> Add -> More Measurements, you can select the expression.
* Sorry, the forum does not show up the square brackets
