at first, exuse me for a bad english :-) and i am begginer in programming oscilloscope, VISA and programing general. The problem is following: i need make many measurements on this oscilloscope. I am saving measured data to 2D array. After first measurements is all ok, i can download data from oscilloscope and save it, but at second measurement is downloaded array empty. It is giving errors: invalid parameter or invalid format at
err=viScanf(vi,"%#hb\n",&num_values, data_byte);
instruction and QUERY INTERRUPTED in Infiinium Application. I am using instructions from Agilent DSO9000 programmers manual (sample programs) in C. Here is simplified code, for 2 measurements:
signed short data_byte [2][25000]; // array to save measured data
int num_values; // quantity of measured data
// initialization of oscilloscope: reset, set trigger, scales, timebase... //
main() {
for(j=0;j<2;j++)
viPrintf (vi, ":SINGLE\n");
// my code (without VISA instructions) //
*Download waveform data.*
*/* Set the waveform source. */*
*viPrintf(vi,":WAVeform:SOURce CHANnel1\n");*
*/* Choose the format of the data returned: */*
*viPrintf(vi,":WAVeform:FORMat word\n");*
*viPrintf(vi,":WAVeform:DATA?\n");*
*/* Read waveform data. */*
*err=viScanf(vi,"%#hb\n",&num_values, data_byte[ j ]);*
*if(err != VI_SUCCESS) printf("ERROR: ");*
*char err_msg[1024]={0};*
*viStatusDesc(vi,err,err_msg);*
*printf("VISAError:%s\n",err_msg);*
*} // end of loop*
*} // end of main*
I am working in Visual Studio. When i use instead of bold instructions :DISK:SAVE:WAVEFORM CHANNEL1,\"D:\\... it is working good for many measurements. I tried more formats like BYTE, ASCii, but the same behavior,no success. Can someone give some advice please? i know, that my code is probably catastrophic and no optimal. When i am write to bad topic, please remove or delete this topic, thank you. If you want more information about code, i will write it.
Mark
Edited by: elemaro on Jan 30, 2013 1:52 PM
main() {
for(j=0;j<2;j++)
*} // end of loop*
*} // end of main*
Mark
Al
