VB:
' Copyright © 2010 Agilent Technologies Inc. All rights
' reserved.
' You have a royalty-free right to use, modify, reproduce and distribute
' the Sample Application Files (and/or any modified version) in any way
' you find useful, provided that you agree that Agilent has no
' warranty, obligations or liability for any Sample Application Files.
' Agilent Technologies provides programming examples for illustration only,
' This sample program assumes that you are familiar with the programming
' language being demonstrated and the tools used to create and debug
' procedures. Agilent support engineers can help explain the
' functionality of Agilent software components and associated
' commands, but they will not modify these samples to provide added
' functionality or construct procedures to meet your specific needs.
'This sample program is intended to use with Microsoft Visual studio 6.0
'and Agilent Visa Object library.
'Sample program execution requires VISA library installation as prerequisite.
'Add below libraries in project reference in Project\reference menu prior to execution of sample 'program:
'VISA COM 3.0 Type Library, Location:\VisaCom\GlobMgr.dll
'VISA COM 488.2 Formatted I/O 1.0, Location:\VisaCom\BasFrmIO.dll
'VISA COM Resource Manager 1.0, Location:\bin\AgtRM.dll
'Signal SUM Example is a sample program that demonstrates the capablity of adding a modulation
'source, in this case channel 2, to a signal on channel 1 and outputting the sum on channel 1.
'Algorithm:
' 1. Configure channel 1 and channel 2 signals.
' 2. Enable channels output.
' 3. Set the type of modulation on channel 1 to SUM.
' 4. Enable modulation output.
' 5. Set the source for channel 1 modulation to channel 2.
' 6. Set the amplitude of the sum.
' 7. For verification, route the channel 1 signal to an oscilloscope to see the result.
'Channel 1 Parameters:
' Wave Shape: Sine
' Frequency: 1000 Hz
' Amplitude: 2 Volt Peak to Peak
' Offset: 0 Volt
' Output Impedence: 50 Ohm
'Channel 2 Parameters:
' Wave Shape: Square
' Offset: 0 Volt
'Modulation:
' Modulation type: Sum Modulation.
' Sum Amplitude: 1%
' Sum State: ON
' Channel1 Output: Enabled
' Channel2 Output: Enabled
Private Sub Command1_Click()
Dim io_mgr As VisaComLib.ResourceManager
Dim mfIo As VisaComLib.FormattedIO488
Set io_mgr = New AgilentRMLib.SRMCls
Set mfIo = New FormattedIO488
Set mfIo.IO = io_mgr.Open(Text1.Text, NO_LOCK, 2000, "")
On Error GoTo MyError
' This program sets up a waveform by selecting the waveshape
' and adjusting the frequency, amplitude, and offset.
With mfIo
' Clear and reset instrument
.WriteString "*CLS"
.WriteString "*RST"
Sleep 1000
' Send commands to set the desired configuration on channel 1
.WriteString "SOURCE1:FUNCTION SIN"
.WriteString "SOURCE1:FREQUENCY 1000"
.WriteString "SOURCE1:VOLT:UNIT VPP"
.WriteString "SOURCE1:VOLT 2"
.WriteString "SOURCE1:VOLT:OFFSET 0"
.WriteString "OUTPUT1:LOAD 50"
' Send commands to set the desired configuration on channel 2
.WriteString "SOURCE2:FUNCTION SQU"
.WriteString "SOURCE2:FREQUENCY 1000"
.WriteString "SOURCE2:VOLT:UNIT VPP"
.WriteString "SOURCE2:VOLT 2"
.WriteString "SOURCE2:VOLT:OFFSET 0"
.WriteString "OUTPUT2:LOAD 50"
' Enable both channel outputs
.WriteString "OUTPUT1 ON"
.WriteString "OUTPUT2 ON"
Sleep 1000
' Enable the modulation on channel 1
.WriteString "SOURCE1:SUM:STATE ON"
' Set modulation source for channel 1 to channel 2
.WriteString "SOURCE1:SUM:SOURCE CH2"
' Set amplitude of modulation to 1%
.WriteString "SOURCE1:SUM:AMPLITUDE 1"
End With
Text2.Text = "Output set as SUM signal on Channel 1"
Exit Sub
MyError:
Text2 = Err.Description
Resume Next
End Sub
Private Sub Form_Load()
Text2.Text = ""
End Sub
' reserved.
'Algorithm:
' Wave Shape: Sine
' Offset: 0 Volt
' Offset: 0 Volt
'Modulation:
' Sum Amplitude: 1%
' Sum State: ON
With mfIo
.WriteString "*CLS"
.WriteString "*RST"
Sleep 1000
Sleep 1000
End With
Exit Sub
MyError:
Resume Next
End Sub
Text2.Text = ""
End Sub
' reserved.
'This sample program is intended to use with Microsoft Visual C++ 2005
'Header file
'at VISA install location. User must point to the file, if not detected
'automatically. Add above header file containing directory as additional
'dependencies for C/C++ project compilation.
'Add visa32.lib library reference as additional dependencies for linker
'in this project. This library can be located at
/* Signal SUM Example is a sample program that demonstrates the capablity of adding a modulation
* source, in this case channel 2, to a signal on channel 1 and outputting the sum on channel 1.
Algorithm:
Wave Shape: Sine
Frequency: 1000 Hz
Offset: 0 Volt
Wave Shape: Square
Frequency: 1000 Hz
Offset: 0 Volt
Modulation:
Sum Amplitude: 1%
Sum State: ON
#include
#include
#include
void main()
ViSession oRm, oMIO;
char strResult[256] = {0};
char noErrString[256] = {"+0,\"No error\"\n"};
char buf[256];
//Mention Visa connection string here.
char instAdd[] = "TCPIP0::146.223.123.106::inst0::INSTR";
//Open a resource manager and create a visa session for communication
viOpenDefaultRM(&oRm);
viOpen(oRm,instAdd,VI_NULL,VI_NULL,&oMIO);
//Query Idendity string and report.
viPrintf(oMIO,"*IDN?\n");
viScanf(oMIO,"%t",&buf);
printf("Instrument Identity String: %s \n", buf);
// Clear and reset instrument
viPrintf(oMIO,"*CLS\n");
viPrintf(oMIO,"*RST\n");
//Send commands to set the desired configuration on channel 1
viPrintf(oMIO,"SOURCE1:FUNCTION SIN\n");
viPrintf(oMIO,"SOURCE1:FREQUENCY 1000\n");
viPrintf(oMIO,"SOURCE1:VOLT:UNIT VPP\n");
viPrintf(oMIO,"SOURCE1:VOLT 2\n");
viPrintf(oMIO,"SOURCE1:VOLT:OFFSET 0\n");
viPrintf(oMIO,"OUTPUT1:LOAD 50\n");
//Send commands to set the desired configuration on channel 2
viPrintf(oMIO,"SOURCE2:FUNCTION SQU\n");
viPrintf(oMIO,"SOURCE2:FREQUENCY 1000\n");
viPrintf(oMIO,"SOURCE2:VOLT:UNIT VPP\n");
viPrintf(oMIO,"SOURCE2:VOLT 2\n");
viPrintf(oMIO,"SOURCE2:VOLT:OFFSET 0\n");
viPrintf(oMIO,"OUTPUT2:LOAD 50\n");
// Enable both channel outputs
viPrintf(oMIO,"OUTPUT1 ON\n");
viPrintf(oMIO,"OUTPUT2 ON\n");
// Enable the modulation on channel 1
viPrintf(oMIO,"SOURCE1:SUM:STATE ON\n");
// Set modulation source for channel 1 to channel 2
viPrintf(oMIO,"SOURCE1:SUM:SOURCE CH2\n");
// Set amplitude of modulation to 1%
viPrintf(oMIO,"SOURCE1:SUM:AMPLITUDE 1\n");
// Read Error
viQueryf(oMIO,"SYST:ERR?\n","%t",&strResult);
if(!(strcmp(strResult,noErrString)))
printf("Sum Signal generated without any error\n");
else
printf("Error reported: %s",strResult);
//Exit
printf("\nPress [Enter] to exit");
getchar();
viClose(oRm);
viClose(oMIO);
