I am using a B2912A SMU controlled with Matlab via GPIB. I would like to use the trigger output pin of the D-Sub connector to trigger another device. Is there a way to controll this pin independent from the trigger of the sources?
Basically I would like to run a measurement without a trigger from the D-Sub and then send a trigger via the D-Sub without performing a measurement.
I hope you can help me with that or at least tell me, if it's possible.
Thanks a lot!
Thanks a lot!
