Thank you Yukata-san, I tend to forget about matlab! This is exactly what I had in mind.
Rich
Richard Kleinhenz
Wafer Engineering
845-892-2617
scubaman@us.ibm.com
fukui.yutaka@jp.f
ujitsu.com
To
10/16/2007 01:06 VRF <vrf@agilent.com>
AM cc
Subject
Please respond to Re: [vrf] quick array help needed
fukui.yutaka@jp.f
ujitsu.com
1)One simple straightforward way may be Formula:
[sum(A[*,0]), sum(A[*,1]), sum(A[*,2])].
However, the number of column must be fixed in this case.
2)Another way is using MATLAB Script B=sum(A).
However, this depends on the VEE version.
FUKUI Yutaka
----- Original Message -----
>Subject: [vrf] quick array help needed
>To: VRF <vrf@agilent.com>
>From: Richard Kleinhenz <scubaman@us.ibm.com>
>Date: Mon, 15 Oct 2007 20:46:05 -0400
>It's been a whle that I've used Vee, and I've lost some basic skills...
>can someone help me out quickly?
>I have a 2D array and would like to produce a vector that is the column
>sum. That ought to be straightforward, but I can't get the simple
>straightforward working, wanted to avoid a complex structure
>Thanks in advance!
>Regards,
>Rich
>Richard Kleinhenz
>Wafer Engineering
>845-892-2617
>scubaman@us.ibm.com
>You are currently subscribed to vrf as: fukui.yutaka@jp.fujitsu.com To
>subscribe please send an email to: "vrf-request@lists.it.agilent.com"
with
the word subscribe in the message body.
>To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com".
>To send messages to this mailing list, email "vrf@agilent.com".
>If you need help with the mailing list send a message to
>"owner-vrf@it.lists.it.agilent.com".
>Search the "unofficial vrf archive" at "
http://www.vrfarchive.com/vrf_archive
>Search the Agilent vrf archive at "http://vee.engineering.agilent.com".
FUJITSU ???(?)????[?9-433] ?????????
?????????·???????? ? ?? ? (FUKUI Yutaka)
INTERNET E-Mail: fukui.yutaka@jp.fujitsu.com
TEL: 044-754-2238(ext:711-5-3153) FAX: 044-754-2434(ext:711-5-3178)
You are currently subscribed to vrf as: scubaman@us.ibm.com To subscribe please send an email to: "vrf-request@lists.it.agilent.com"
with the word subscribe in the message body.
http://www.vrfarchive.com/vrf_archive".
Rich
Richard Kleinhenz
Wafer Engineering
845-892-2617
scubaman@us.ibm.com
fukui.yutaka@jp.f
ujitsu.com
To
AM cc
Subject
fukui.yutaka@jp.f
ujitsu.com
FUKUI Yutaka
>Thanks in advance!
>Regards,
>Rich
>Richard Kleinhenz
>Wafer Engineering
>845-892-2617
>scubaman@us.ibm.com
with
I have a 2D array and would like to produce a vector that is the column sum. That ought to be straightforward, but I can't get the simple straightforward working, wanted to avoid a complex structure
Thanks in advance!
Rich
Richard Kleinhenz
Wafer Engineering
845-892-2617
scubaman@us.ibm.com
