I am using Benchlink to generate a waveform which I want to download to a 33522B waveform generator. Everything works fine until I press Send Data to Instrument. The I get a message: Error occurer "Input string not in correct format". And then another error message: "Object reference not set to an instance of an object". If I click OK for the message windows the program crash. The attached file show a screen dump just before the crash.
Anybody familiar with this problem? How can it be solved?
The software is the base version 3.0 included with the instrument.
Leif
Leif
If you update the instrument firmware, and the software, I believe your probably will be resolved.
If it doesn't please let us know.
