Hi, May I know whether we can apply analog Amplitude Modulation (AM) on multitone signals using E4438C ESG or E8267D PSG Vector Signal Generator? Please help.
The answer is yes, Amplitude Modulation (AM) can be applied to multitione signals being generated using the E4438C ESG, or the E8267D PSG Vector Signal Generators.
Use the AM menu to apply the modulation to mutiltone signals exactly the same as when applying to a CW signal.
Regards -
