Firstly, going through the documentation and especially the Programmers Reference Help I couldn't find any clock reference, hence I assume there isn't a clock in the device which I can use for Synchronization with the PC.Correct?
Secondly, in order to acquire real-time measurements, I have to use the TRIG:COUN INF command. The trigger delay will be the delay between each reading (if sample count is 1), but how much time is required to take the measurement and store it to the buffer? Is it significant enough to even consider it?
Thank you in advance.
Marinos
Marinos
I hope this helps
Russ
