William.Drago@L-3com.com wrote:
> Well, I let VEE do the compile for me. It does that when you specify a
> .id instead of a .cid.
I found way too many cases where this didn't work right- including with VEERUN, so I always do the compile myself
> As for the compiler itself, when I start it a dos window opens then
> closes immediately. It doesn't prompt for the filename?
as with most command-line programs there's a brief help available:
idc -? will give you the syntax.
idc [-o output_directory] id_file
regards
Stan
regards
Stan
I've tried this, but there's only .id files.
http://adn.tm.agilent.com/index.cgi?CONTENT_ID=563
I am looking specifically for the hp436.cid driver
Bill
