I am trying to automise the parameter tuning of the models by using the optimization function.
Unfortunately I am not able to run it, since I don´t know what I have to define in "Expr" . The examples
in the knowledge base handle always S-parameter as target or goal. I want to use measurement data of voltages or currents. I want to simulate the IV Characteristics of the Internal Diode in the HISIM_HV and match the measurement data using the Optimizer..
Kindly lemme know how to go ahead with this issue.
Regards
Leela
Regards
Leela
I recommend you start with this example on the Knowledge Center: http://edocs.soco.agilent.com/display/eesofkcads/optimizing+iv+curves+vs+measured+data
