I've scoured the internet for hours trying to figure this out, and I keep seem to find an answer. According the SCPI reference manual, you can specify a file name via MMEM:DOWN:FNAM, and then write to that file using the command MMEM:DOWN:DATA <binary_block>. The example given in the manual is #15Hello. My question is, how is the number 15 calculated? How about some other examples, such as the following:
Data Type:"short"
Thanks.
Data Type:"short"
Thanks.
Check it out and let me know if you have questions:
view
