I have setup a LabVIEW program using 33250A instrument library. The program successfully configures my waveform and delayed trigger. However, I want my program react to the external trigger (Trig In) on the back of the 33250A. I want to be able to query the 33250 and get a response back that the 33250 received the trigger and that it is counting down to output the burst I programmed under a delayed trigger. I don't see a command like this... only when the whole sequence is complete.
Is this possible with the 33250A? If not, is there another way to monitor when the 33250A receives the external trigger other than having a separate DIO or DAQ card?
