vrf Defaults
Question asked by fukui.yutaka on Apr 27, 2008
Because VEE program file is saved as a text file, we can edit it using a text editor.
Default title("Formula") of a "FORMULA" object that is not listed in the "default preferences" section is described in the file as:
(device 0 FORMULA
(properties
(name "Formula")
If we replace a line (name "Formula1") for (name "Formula"), then the object title changes from "Formula" to "Formula1".
May this information help you.
FUKUI Yutaka
----- Original Message -----
>Subject: [vrf] Defaults
>Date: Fri, 25 Apr 2008 10:31:21 -0400
>From: "Boespflug, Matthew (GE, Research)" <boespflu@research.ge.com>
>To: VRF <vrf@agilent.com>
>Is there a way to set defaults for properties not listed in the
>"default preferences" section? I would like to set defaults for object
>properties such as appearance and title rather than change each
>individually (gets time consuming when you have 100+ objects in a GUI).
>Thanks in advance for any help.
>Matthew Boespflug
>GE Global Research
>1 Research Circle
>ES - 508c
>Niskayuna, NY 12309
>Phone: 518-387-5017
>Fax: 518-387-7989
>GE Company Proprietary Information
>www.geglobalresearch.com
>You are currently subscribed to vrf as: fukui.yutaka@jp.fujitsu.com To
>subscribe please send an email to: "vrf-request@lists.it.agilent.com"
>with
the word subscribe in the message body.
>To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com".
>To send messages to this mailing list,  email "vrf@agilent.com".
>If you need help with the mailing list send a message to
>"owner-vrf@it.lists.it.agilent.com".
>Search the "unofficial vrf archive" at
>"http://www.vrfarchive.com/vrf_archive
>Search the Agilent vrf archive at "http://vee.engineering.agilent.com".
FUJITSU ???(?)????[?9-432] ?????????
  ?????????)??·?????????? ? ??  ? (FUKUI Yutaka) INTERNET E-Mail: fukui.yutaka@jp.fujitsu.com
TEL: 044-754-2238(ext:711-5-3153)     FAX: 044-754-2434(ext:711-5-3178)
