I controlling an 33250A arb. waveform generator using labview 2011. I am looking to produce a signal that has 4 sin-wave "pulses" that occur at fixed times, say 0microsecods, 2 microsecods, 5 microseconds, and 10 microseconds. Each pulse would be the same number of cycles at the same amplitude. It seems that burst mode only allows a fixed separation between pulses. How would I accomplish this?
Thanks for any help,
Eric
Eric
So is the delay between pulses a fixed sequence or is the delay order constantly changing? If it is repeatable you could create an arbitrary waveform with the appropriate DC gaps between sine waves to create the necessary delays.
