Hi David,
To/From Socket -object does the tricks. Make e.g. "device_read"- and "device_write"-functions and place box there, along with control terminals for address, etc. if desired.
In "write" connect to port specified (2323?) and write string + delimiters. In "read", also connect port (not bind, that is) and read e.g. str or what data you're expecting after writes.
BR,
-Antti
> -----Original Message-----
> From: Mairs, David [mailto:david.mairs@hp.com]
> Sent: 21 September 2007 14:52
> To: VRF
> Subject: [vrf] Telnet VEE
> To All
> I am looking for a telnet routine?
> Any Help Would BE Greatly Appreciated.
> Thanks,
> Dave
Please note: This e-mail may contain confidential information intended solely for the addressee. If you have received this e-mail in error, please do not disclose it to anyone, notify the sender promptly, and delete the message from your system.
Thank you.
BR,
-Antti
> To: VRF
> To All
> Thanks,
> Dave
Thank you.
Dave
