Hi William,
i have the same problem. The only way i see is to put it into formular with
charToInt an then you become "10". Now you can check it with if/then/else.
Sebastian
Sebastian Donner
KRIWAN Testzentrum GmbH & Co. KG
Teslastr.2, D-74670 Forchtenberg
Tel: 07947/9150-0 Fax: 07947/9150-50
Sebastian.Donner@KRIWAN-Testzentrum.de
www.KRIWAN-Testzentrum.de
Von: William.Drago@L-3com.com [mailto:William.Drago@L-3com.com]
Gesendet: Freitag, 21. September 2007 14:57
An: VRF
Betreff: RE: [vrf] From String Bug
Hi Antti,
Well, that works, but since there is no CR or LF in the string to begin with I shouldn't have to filter them.
The problem I'm pointing out is that From String adds a CR when it doesn't find any excluded characters. I find this behavior odd don't you?
Bill
From: Antti.Suhonen@elektrobit.com [mailto:Antti.Suhonen@elektrobit.com]
Sent: Friday, September 21, 2007 1:37 AM
To: VRF
Subject: RE: [vrf] From String Bug
Hi Bill,
READ TEXT x TOKEN EXCLUDE "3
" is what you're looking for.
BR,
-Antti
_____
From: William.Drago@L-3com.com [mailto:William.Drago@L-3com.com]
Sent: 20 September 2007 23:53
To: VRF
Subject: [vrf] From String Bug
All,
Read Text x Token Exclude adds an extra char if nothing from the exclusion list is found. See attached.
Bug or expected behavior?
Bill
Please note: This e-mail may contain confidential information
intended solely for the addressee. If you have received this
e-mail in error, please do not disclose it to anyone, notify
the sender promptly, and delete the message from your system.
Thank you.
You are currently subscribed to vrf as: William.Drago@l-3com.com
You are currently subscribed to vrf as: sebastian.donner@kriwan-testzentrum.de
Diese E-Mail enthaelt vertrauliche und/oder rechtlich geschuetzte Informationen. Wenn Sie nicht der richtige Adressat sind oder diese E-Mail irrtuemlich erhalten haben, informieren Sie bitte sofort den Absender und loeschen Sie diese Mail. Das unerlaubte Kopieren sowie die unbefugte Weitergabe dieser Mail ist nicht gestattet.
Eingehende E-Mails mit folgenden Anhangs-Endungen werden aus sicherheitsgründen automatisch abgewiesen:
PIF, SCR, BAT, URL, EXE, COM, DLL, HTA, VBS
This e-mail may contain confidential and/or privileged information. If you are not the intended recipient (or have received this e-mail in error) please notify the sender immediately and delete this e-mail. Any unauthorized copying, disclosure or distribution of the contents in this e-mail is strictly forbidden.
Incoming E-Mails with the following attachement-extensions are automatically rejected for security reasons:
KRIWAN Testzentrum GmbH & Co. KG - AG Stuttgart: HRA 590480
Komplementär:
KRIWAN Verwaltungs-GmbH - AG Stuttgart: HRA 590645
Geschäftsführer: Dr. Ing. Elmar Zeitler, Dipl.-Ing. Jens-Peter Huischen
Sebastian
Sebastian Donner
An: VRF
Hi Antti,
Bill
To: VRF
Hi Bill,
BR,
-Antti
_____
To: VRF
All,
Bill
Thank you.
Komplementär:
