Hello Claudia,
Thanks for your reply. I have done some thing similar to your suggestion.I have set highest priority for MS Excel in the task manager , Stopped all other user application.. now it seems ok.. atleast in the first trial !!
Thanks and regards,
Sudip
_____
Von: Willging, Claudia [mailto:claudia.willging@kriwan-testzentrum.de]
Gesendet: Mittwoch, 7. Mai 2008 13:01
An: Sudip Chattopadhyay (GS-EC/EEM3 RBIN); VRF
Betreff: AW: [vrf] Why code stops sometimes with error ?
Hello Sudip,
unfortunately I cannot tell you the reason for the error-massage you get. Maybe someone else is using the Excel-Sheet while your program tries to write to it. Also you could check in your task manager, if Excel is running several times when the error occurs. Make sure, only the Excel-application you need for your measurement is running.
There is a german Vee-Forum where you can find a download concerning Active X and Excel: http://www.my-vee.de/download.shtml
It might be helpful for you.
Mit freundlichen Grüßen
i. A. Claudia Willging
Dr. Claudia Willging
KRIWAN Testzentrum GmbH & Co. KG
D-74670 Forchtenberg
Tel.: (07947) 9150-0 (Durchwahl 9365) Fax: (07947) 9150-50
claudia.willging@KRIWAN-Testzentrum.de
www.KRIWAN-Testzentrum.de
>> Besuchen Sie uns auf der AUTOMOTIVE TESTING EXPO vom 06. - 08. Mai 2008 / Messe Stuttgart / Halle 1 / Stand Nr. 1008 <<
Von: Sudip Chattopadhyay (GS-EC/EEM3 RBIN) [mailto:Chattopadhyay.Sudip@de.bosch.com]
Gesendet: Dienstag, 6. Mai 2008 09:54
An: VRF
Betreff: [vrf] Why code stops sometimes with error ?
Hello Everybody,
This is my first code in VEE to do some repeatative mesurements for some ADC. Some times the entire range of mesurements run successfully and sometimes it stops in between with the error message as shown in the attached message.
<<error_location.gif>>
Once this error comes I need to start the entire measurements from the begining. Can any body tell what shall I do to avoid this stopping of code execution in the middle of my measurement ? Is there anything related to the version of the VEE ( 6.2) or MS office excel (2003) I am using ?
Waiting for response.
Thanks and regards,
Sudip
You are currently subscribed to vrf as: claudia.willging@kriwan-testzentrum.de
Diese E-Mail enthaelt vertrauliche und/oder rechtlich geschuetzte Informationen. Wenn Sie nicht der richtige Adressat sind oder diese E-Mail irrtuemlich erhalten haben, informieren Sie bitte sofort den Absender und loeschen Sie diese Mail. Das unerlaubte Kopieren sowie die unbefugte Weitergabe dieser Mail ist nicht gestattet.
Eingehende E-Mails mit folgenden Anhangs-Endungen werden aus sicherheitsgründen automatisch abgewiesen:
PIF, SCR, BAT, URL, EXE, COM, DLL, HTA, VBS
This e-mail may contain confidential and/or privileged information. If you are not the intended recipient (or have received this e-mail in error) please notify the sender immediately and delete this e-mail. Any unauthorized copying, disclosure or distribution of the contents in this e-mail is strictly forbidden.
Incoming E-Mails with the following attachement-extensions are automatically rejected for security reasons:
KRIWAN Testzentrum GmbH & Co. KG - AG Stuttgart: HRA 590480
Komplementär:
KRIWAN Verwaltungs-GmbH - AG Stuttgart: HRA 590645
Geschäftsführer: Dr. Ing. Elmar Zeitler, Dipl.-Ing. Jens-Peter Huischen
Thanks and regards,
Sudip
_____
Hello Sudip,
An: VRF
Hello Everybody,
Thanks and regards,
Sudip
Komplementär:
An: VRF
Hello Everybody,
Thanks and regards,
Sudip
Komplementär:
