In order to download arbitrary waveforms over 64K points to the 33521A and 33522A you must convert to binary.
Attached is a program that makes this easy. Simply input your array and give your arb a name and the vi will convert it and send it to the 33522A.
Also attached is an example program that uses this vi to download 2 million data points to your 33521A.
