Hi, I created a program in VEE that will download a 1MSample arbitrary Waveform. It must be done with binary data. You can only download a 64KB arbitrary waveform using ASCII data format. Please see that attached image for the VEE program. Even if you don't use VEE, you can see the SCPI commands needed to download the file.![Image]()
