Hi, I'm new to HP6812B which I want to use to generate DC transients to test equipment (category Z) according to DO-160D standard. For this purpose GPIB controlled HP6812B with LIST mode looks as a perfect solution. I could generate the DC transients from the HP6812B local keyboard, but I can't generate transients while programming remotely with LIST.
What is wrong with this example?
*RST
OUTP:COUP DC DC operation only
VOLT:OFFS 27.5; :VOLT 0 initial 27.5V DC
OUTP ON
LIST COUN 2 repeat 2 times
VOLT:MODE LIST
LIST:VOLT:OFFS 27.5,13.75 27.5V DC for 10s and 13.75V DC for 10.5ms
LIST:DWEL 10, 0.0105
LIST:STEP AUTO List to be paced by Dwell time
TRIG:SOUR BUS GPIB is source of trig
INITiate IMMediate:SEQuence1 generates trigger when the trigger is initiated
*TRG trigger it from BUS
*RST
OUTP ON
VOLT:MODE LIST
Are you getting an error of some sort? Your number of dwell points does not match your number of voltage points. These need to match.
