Hi Fengzhou Wang,
thank you for your fast answer (best support for user). We start the setup with setup.exe /v"/l*v "c:install.log""
the command line pops up and close often and the setup finished wit success I'm sorry but I don't now why???
No log file is created and vee works.
We reinstall vee for test and install it again with setup.exe without command line.
It works perfect.... no blue screen no problem with installation. Why?
Best regards
Sebastian
Mit freundlichen Grüßen
i. A. Sebastian Donner
Softwareentwicklung
Sebastian Donner
KRIWAN Testzentrum GmbH & Co. KG
Teslastr.2, D-74670 Forchtenberg
Tel: 07947/9150-0 (Durchwahl 9365) Fax: 07947/9150-50
Sebastian.Donner@KRIWAN-Testzentrum.de
www.KRIWAN-Testzentrum.de
Von: feng-zhou_wang@agilent.com [mailto:feng-zhou_wang@agilent.com]
Gesendet: Donnerstag, 24. Januar 2008 09:46
An: Donner, Sebastian
Cc: vee_support@agilent.com
Betreff: RE: [vrf] VEE and Vista crash wir blue screen
Hi Sebastian,
I am Fengzhou Wang from Agilent VEE team. For this installation problem, I have 3 questions for you. I suppose you are using VEE Pro 8.5.
1 Have your tried to run setup.exe of Agilent VEE Pro, then select “Remove” to uninstall VEE Pro 8.5?
2 Could you please install VEE Pro 8.5 from command line: setup.exe /v"/l*v "c:install.log"", then send the install.log to us.
3 And catch a picture when VEE stuck during the above reinstallation of VEE?
Best regards,
Fengzhou Wang
_____
From: Donner, Sebastian [mailto:sebastian.donner@kriwan-testzentrum.de]
Sent: Thursday, January 24, 2008 3:45 PM
Subject: [vrf] VEE and Vista crash wir blue screen
Hi vrf,
we have big problems with Vee 8.5 and Windows Vista.
We installed IO Lib 15 and it works fine.
Then we installed VEE 8.5, at 50% the installation crashed with blue screen and the system restart automatically
We started to install VEE again but VEE says
".dll not found".
Another start of the installation is no longer possible.
System:
Vista Business (German)
Intel Core 2 Duo
2GB Ram
Boot Manager with XP and Vista running.
Any idea?
Thanks
Softwareentwicklung
Sebastian Donner
You are currently subscribed to vrf as: feng-zhou_wang@agilent.com
Diese E-Mail enthaelt vertrauliche und/oder rechtlich geschuetzte Informationen. Wenn Sie nicht der richtige Adressat sind oder diese E-Mail irrtuemlich erhalten haben, informieren Sie bitte sofort den Absender und loeschen Sie diese Mail. Das unerlaubte Kopieren sowie die unbefugte Weitergabe dieser Mail ist nicht gestattet.
Eingehende E-Mails mit folgenden Anhangs-Endungen werden aus sicherheitsgrunden automatisch abgewiesen:
PIF, SCR, BAT, URL, EXE, COM, DLL, HTA, VBS
This e-mail may contain confidential and/or privileged information. If you are not the intended recipient (or have received this e-mail in error) please notify the sender immediately and delete this e-mail. Any unauthorized copying, disclosure or distribution of the contents in this e-mail is strictly forbidden.
Incoming E-Mails with the following attachement-extensions are automatically rejected for security reasons:
KRIWAN Testzentrum GmbH & Co. KG - AG Stuttgart: HRA 590480
Komplementar:
KRIWAN Verwaltungs-GmbH - AG Stuttgart: HRA 590645
Geschaftsfuhrer: Dr. Ing. Elmar Zeitler, Dipl.-Ing. Jens-Peter Huischen
Best regards
Sebastian
Softwareentwicklung
Sebastian Donner
Hi Sebastian,
Best regards,
Fengzhou Wang
_____
Hi vrf,
".dll not found".
System:
Intel Core 2 Duo
2GB Ram
Any idea?
Thanks
Softwareentwicklung
Sebastian Donner
Komplementar:
