> I have used VEE to design a temperature control system for a
> resistance heated furnace. I have written a program such that the
> temperature ramps up to a setpoint, T1, and then when the temperature
> is (approaching!) stable a cycling program kicks in and the
> temperature cycles between two setpoints, T1 and T2. I have used an
> adapted version of the PID controller available with the VEE software
> to attempt to smooth out the approach to each setpoint*.
> It is with the PID control that I have been experiencing problems:
> not only is the trial and error method time consuming, the performance
> of the furnace varies with time (heating of
> electrodes) so PID values from early cycles often become redundant
> later on. I've been wondering about an autotune system, but I don't
> really know where to start. Can anyone offer me any advice?
This is not a simple problem. I would imagine that a furnace is slow enough that VEE could be used to set up a reasonably good controller. There are certain rules and recipies to set the parameters of a text-book PI(D) controller, which involves measuring the oscillation period if the gain is set too high on purpose and using this as time for the integration. Afterwards lower the gain until the oscillation ceases and half the gain. In my experience with temperature controllers any derivative action does not really help alot, so staying with a PI controller is in most of the times good enough.
I do not have any experience with fuzzy logic but I hear there are certain benefits for complex systems that are hard to describe and possibly time varrying. So maybe digging into fuzzy logic might give some interesting new ideas.
Bernd
PS What sometimes works is to create an array of PI-values in the above described way for different target temperatures and modify the controller as the actual set point or actual temperature changes. This way you always have the "best" controller in place.
Bernd
I have used VEE to design a temperature control system for a resistance heated furnace. I have written a program such that the temperature ramps up to a setpoint, T1, and then when the temperature is (approaching!) stable a cycling program kicks in and the temperature cycles between two setpoints, T1 and T2. I have used an adapted version of the PID controller available with the VEE software to attempt to smooth out the approach to each setpoint*.
not only is the trial and error method time consuming, the performance of the furnace varies with time (heating of electrodes) so PID values from early cycles often become redundant later on. I've been wondering about an autotune system, but I don't really know where to start. Can anyone offer me any advice?
Thank you for your time,
John
As an aside: is it possible to get execution flow to pass through userobjects? I can't seem to make this happen.
*Taking into account a 'bias value' that corresponds to the steady state required power output for the setpoint temperature, as well as a couple of other features for quick approach between setpoints.
(I did find this on the VRF archive - http://www.vrfarchive.com/
SearchVRF.php?mi=12354 - which I almost wish I'd seen before setting up the control system as I'm loathe to give up now having put in so much time)
