Continue HB sweep after a single point fails to converge
Question asked by curtis on Nov 13, 2012
Latest reply on Nov 29, 2012 by Toby
Is there a way to force the harmonic balance simulator to proceed to the next sweep point after a convergence failure?  The simulation currently stops after any convergence error.
I am using TAHB with a parameter sweep block.  This should cause each swept point to be individually calculated.  I see no reason why the simulator can't continue to the next point when one point fails.
Any tips or suggestions would be appreciated.  Thanks.
