Hi All
Does anyone have an example of how to upload a binary object (such as a jpg or other file) to a SQLServer database field using ADO.net.
I currently talk to the SQL server using ADO.net and the oledbconnection.
Someone who uses ADO.net through VB has given me an example SQL string that looks like:
Cmd = "UPDATE " & TableName & " SET " & FieldName & " = @img WHERE ID=" & ID
In his case, he stores the file to large byte array called img before running this SQL command.
I just can’t get my head around how to use this command from within vee. Any help would be greatly appreciated.
Thanks and regards
Nick
Thanks and regards
Nick
