I do not understand what the "pointer is jumping ahead" mean but ...
For your infomation:
If I remember correctly, VEE has only one pointer to one file.
That is, even if multiple "From File" objects file exist to the same file, there exists only one pointer to the file. So, if you read a data from a file with one of the "From File" object, the next read with another "From Fi le" object reads the next data from a file.
FUKUI Yutaka
----- Original Message -----
>From: "Claflin, Carrie" <carrie.claflin@hp.com>
>To: VRF <vrf@agilent.com>
>Date: Wed, 5 Sep 2007 22:06:06 +0000
>Subject: [vrf] I'm losing characters between From File transactions
>I have an application that basically has to dissect a file and pull out
>the v
alue pairs that I need. Between From File boxes it looks like the pointer is jumping ahead. I use the alphanumeric output to see what is read and it is de finitely jumping ahead.
>Does anyone have any experience with this?
>You are currently subscribed to vrf as: fukui.yutaka@jp.fujitsu.com To
>subscribe please send an email to: "vrf-request@lists.it.agilent.com"
>with
the word subscribe in the message body.
>To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com".
>To send messages to this mailing list, email "vrf@agilent.com".
>If you need help with the mailing list send a message to
>"owner-vrf@it.lists.it.agilent.com".
>Search the "unofficial vrf archive" at
>"http://www.vrfarchive.com/vrf_archive
>Search the Agilent vrf archive at "http://vee.engineering.agilent.com".
FUJITSU ???(?)????[?9-433] ?????????
?????????·???????? ? ?? ? (FUKUI Yutaka)
INTERNET E-Mail: fukui.yutaka@jp.fujitsu.com
TEL: 044-754-2238(ext:711-5-3153) FAX: 044-754-2434(ext:711-5-3178)
FUKUI Yutaka
>the v
>with
