Hello all, I am trying to manage a Telnet communication sending and receiving messages and data programmatically using VEE. I searched the archive and I understand that someone already did this, but I was not able to find out any example. Does it exist a tutorial on this topic anywhere ? Are examples available ? Thank in advance Enrico
--- You are currently subscribed to vrf as: ming_meng@agilent.com To subscribe please send an email to: "vrf-request@lists.it.agilent.com" with the word subscribe in the message body. To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com". To send messages to this mailing list, email "vrf@agilent.com". If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com". Search the "unofficial vrf archive" at "http://www.vrfarchive.com/vrf_archive". Search the Agilent vrf archive at "http://vee.engineering.agilent.com".
> Does it exist a tutorial on > this topic anywhere?
Not exactly a tutorial, but a definition. RFC 854. http://www.faqs.org/rfcs/rfc854.html -SHAWN-
Hi, I have done this (it is a bit convoluted), and we use it constantly. However, I am about 1000 miles away from my desk at the moment. I can send you the code in about 1 week.
David Watling
-----Original Message----- From: enrico galletti [mailto:e.galletti@seletech.com] Sent: 19 February 2008 08:25 To: VRF Subject: [vrf] Managing a Telnet session from VEE
--- You are currently subscribed to vrf as: watling@icerasemi.com To subscribe please send an email to: "vrf-request@lists.it.agilent.com" with the word subscribe in the message body. To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com". To send messages to this mailing list, email "vrf@agilent.com". If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com". Search the "unofficial vrf archive" at "http://www.vrfarchive.com/vrf_archive". Search the Agilent vrf archive at "http://vee.engineering.agilent.com".
-- ****************************************************************************************** This e-mail (including any attachments) is intended only for the recipient(s) named above. It may contain confidential or privileged information and should not be read, copied or otherwise used by any other person. If you are not a named recipient, please contact the sender by telephone (+44-1454-284800) and destroy the original message. Any statement and/or opinion not related to this company's business and expressed in this message is that of the author and does not necessarily reflect those of Icera. This company does not take any responsibility for the views of the author in any matter not related to the company's objective. ******************************************************************************************
You can certainly get time domain information by doing an inverse FFT (IFFT) to the spectrum. However, as you correctly assume, you have a lot of missing data in a magnitude spectrum. The phase information is missing, and also your inverse FFT will assume that the spectrum doesn’t change over the timespan.
Regards
David Watling
_____
From: wsh wsh [mailto:wshooa@yahoo.com] Sent: 23 February 2008 22:48 To: VRF Subject: [vrf] demodulation
hi all
i make a program using a spectrum analyzer to detect the analoge modulation ( FM/AM ) and save the trace to file .......
can i use this saved data to get its time domain signal and demodulat it to get the audio signal ? or get the audio signal directly from it ?
i now that the spectrum output not include the phase component so can i generate it in order to get the audio signal .....
any help
ok
_____
Be a better friend, newshound, and know-it-all with Yahoo! Mobile. HYPERLINK "http://us.rd.yahoo.com/evt=51733/*http:/mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ%20"Try it now. --- You are currently subscribed to vrf as: watling@icerasemi.com To subscribe please send an email to: "vrf-request@lists.it.agilent.com" with the word subscribe in the message body. To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com". To send messages to this mailing list, email "vrf@agilent.com". If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com". Search the "unofficial vrf archive" at "http://www.vrfarchive.com/vrf_archive". Search the Agilent vrf archive at "http://vee.engineering.agilent.com".
-- _____
This e-mail (including any attachments) is intended only for the recipient(s) named above. It may contain confidential or privileged information and should not be read, copied or otherwise used by any other person. If you are not a named recipient, please contact the sender by telephone (+44-1454-284800) and destroy the original message. Any statement and/or opinion not related to this company's business and expressed in this message is that of the author and does not necessarily reflect those of Icera. This company does not take any responsibility for the views of the author in any matter not related to the company's objective. _____
Thank-you very much, Dave. I shall try to learn from your example. In the meanwhile I also found out a useful open-source ActiveX control to manage socket connections, which is useful for Telnet too. It is part of an ActiveX collection that can be found at "http://activex.sourceforge.net/". Some other potentially useful ActiveX controls are available there, so I think it is worth to have a look. Sincerely, Enrico
The information included in this e-mail and any attachments are confidential. If you are not the correct recipient, you are kindly requested to notify the sender immediately, to cancel it and not to disclose the contents.
Le informazioni contenute in questo messaggio di posta elettronica sono confidenziali e ne e' vietata la diffusione in qualsiasi forma. Qualora Lei non fosse la persona destinataria del presente messaggio, La invitiamo ad eliminarlo e a non diffonderlo, dandone gentilmente comunicazione al mittente.
> > -------- Original Message -------- > Subject: Re:[vrf] Managing a Telnet session from VEE > From: David Watling <watling@IceraSemi.com> > To: VRF <vrf@agilent.com> > Date: Mon Feb 25 2008 11:18:06 GMT+0100 (ora solare Europa > occidentale) > > Ok, here it is (at last!) > Hop it helps. > > Dave Watling > > -----Original Message----- > From: enrico galletti [mailto:e.galletti@seletech.com] > Sent: 19 February 2008 08:25 > To: VRF > Subject: [vrf] Managing a Telnet session from VEE > > Hello all, > I am trying to manage a Telnet communication sending and receiving > messages and data programmatically using VEE. > I searched the archive and I understand that someone already did this, > but I was not able to find out any example. Does it exist a tutorial > on this topic anywhere ? Are examples available ? > Thank in advance > Enrico > > > --- > You are currently subscribed to vrf as: watling@icerasemi.com To > subscribe please send an email to: "vrf-request@lists.it.agilent.com" > with the word subscribe in the message body. > To unsubscribe send a blank email to > "leave-vrf@it.lists.it.agilent.com". > To send messages to this mailing list, email "vrf@agilent.com". > If you need help with the mailing list send a message to > "owner-vrf@it.lists.it.agilent.com". > Search the "unofficial vrf archive" at > "http://www.vrfarchive.com/vrf_archive". > Search the Agilent vrf archive at "http://vee.engineering.agilent.com". > > > -- > ********************************************************************** > ******************** This e-mail (including any attachments) is > intended only for the recipient(s) named above. It may contain > confidential or privileged information and should not be read, copied > or otherwise used by any other person. If you are not a named > recipient, please contact the sender by telephone (+44-1454-284800) > and destroy the original message. > Any statement and/or opinion not related to this company's business > and expressed in this message is that of the author and does not > necessarily reflect those of Icera. This company does not take any > responsibility for the views of the author in any matter not related > to the company's objective. > ********************************************************************** > ******************** > > --- > You are currently subscribed to vrf as: e.galletti@seletech.com To > subscribe please send an email to: "vrf-request@lists.it.agilent.com" with the word subscribe in the message body. > To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com". > To send messages to this mailing list, email "vrf@agilent.com". > If you need help with the mailing list send a message to > "owner-vrf@it.lists.it.agilent.com". > Search the "unofficial vrf archive" at "http://www.vrfarchive.com/vrf_archive". > Search the Agilent vrf archive at "http://vee.engineering.agilent.com".
Thank in advance
Enrico
