"POON,CHENG-FOO (A-Malaysia,ex1)" <cheng-foo_poon@agilent.com> wrote:
> Hi Eddie,
> May I know which version that you are using? I'm using the VEE 8.5,
> and I can see the Copy menu in my UserFunction right click context menu.
> You can give it a try by right-clicking the UserFunction's title bar,
> and the Copy menu should be available in that drop down context menu.
Looks like "Copy" was added for VEE 5 but "clone" has been around since UF's were added. I checked all versions from 5 thru 8 and all have the 'copy" menu pick.
Make sure that you are looking at the UF's title bar menu.
Stan
> Hi Eddie,
Stan
is there a way to copy and paste a UF?
It looks like as its only possible to cut the UF and then paste it twice. Is this correct?
Why is the cut-command only available in the "right-click-on-UF-menue" and not as keyboard-shortcut "STRG+X"?
Are there any plausible explanations why it is like this?
Thx
