Here are a few ideas:
Get a faster computer
Make sure the program file is defragmented. If Sleuthkit istat shows only one cluster run, it will load faster than if the OS has to bounce all over the disk to get the data.
If you use Automation libraries, you can reduce load time by unchecking them in Automation Library References. Unfortunately you can only do this if you're not declaring object variables or using Controls or Events. The CreateObject call is all that's strictly necessary. There are probably similar tips for .NET (dynamically loading assemblies for instance).
Provide a small program that displays a "splash" screen and then loads the main program.
-SHAWN-
-SHAWN-
As my VEE program is getting bigger, it takes longer time to launch it on VEE Runtime version. And it doesn’t look beautiful showing the grey-colored launching screen of VEE Runtime version until it is ready.
Any idea will be appreciated, to reduce the VEE Runtime launching time. Or could we just hide the grey-colored launching screen and show other fake image?
JC Park
