"an array of data which is retrieved from a access.mdb file, then fed to an x y plot display, unfortunately amongst the data there are a lot of 0's which make
the resulting graph very untidy.
Can any one suggest a way of converting the 0's to nothing."
Sure-- use the comparator with copmparison set to "==0" and then the rest of the array will pop out of the "failures" pin
All of 2 VEE objects. Fast and efficient.
Stan
Stan
