hi!
in ads momentum , we use an infinite ground plane
is this cas , *does for exemple patch antenna support the propagation of surface wave?*
NB: Surface waves come into existence at the interface between two different media (for example an interface between two different dielectrics)
look attach files to know more.
if momentum does not take into account the propagation of surface wave ,
how to do in order to take into account these surface waves with momentum ads?
thank you!
thank you!
