vrf The ouput is an object, I need help?
Question asked by VRFuser on May 19, 2008
Use
asint32(fi.Length.ToString());
To get a 32 bit integer, however there is a danger since the output is actually a 64 bit integer so if the value is out of range then you will get an error.
Sent: 19 May 2008 16:08
To: VRF
Subject: [vrf] The ouput is an object, I need help?
The output from the formula is an object, I need to be able to feed to an "IfTheElse", can the object be change to text?
If so how?
Dave
You are currently subscribed to vrf as: Jacob.Meachen@adckrone.com To subscribe please send an email to: "vrf-request@lists.it.agilent.com"
with the word subscribe in the message body.
Search the "unofficial vrf archive" at
"http://www.vrfarchive.com/vrf_archive".
