I am trying to measure pulse droop from a trace using a N1912 power meter. When I use the trace mode to display data, the markers connected with the gate do not show the correct power level. The data is plotted correctly on the trace (at the correct power level), but the value read from the markers is incorrect. The marker value changes when the "Y Max" or "Y Scale Div" values are changed. Has anyone else come across a fix for this problem?
Thank you.
Thank you.
